Ana içeriğe geç
Toshiba Thrive Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Thrive Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Speakers Replacement: adım 2, 2 resimden 1. Toshiba Thrive Speakers Replacement: adım 2, 2 resimden 2.
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Speakers Replacement: adım 3, 1 resimden 1.
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Speakers Replacement: adım 4, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 4, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 4, 3 resimden 3.
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Speakers Replacement, Speakers: adım 5, 2 resimden 1. Toshiba Thrive Speakers Replacement, Speakers: adım 5, 2 resimden 2.
    • Start by using a PH0 phillips head screwdriver to remove the 12 screws holding on the back cover
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Speakers Replacement: adım 6, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 6, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 6, 3 resimden 3.
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Speakers Replacement: adım 7, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 7, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 7, 3 resimden 3.
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Speakers Replacement: adım 8, 2 resimden 1. Toshiba Thrive Speakers Replacement: adım 8, 2 resimden 2.
    • carefully open the device like a book and lay the two halves beside each other.
    • put the screen assembly in a safe place as you complete the rest of the guide.
  9. Toshiba Thrive Speakers Replacement: adım 9, 2 resimden 1. Toshiba Thrive Speakers Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to open the latch holding the last wire to the back of the device.
  10. Toshiba Thrive Speakers Replacement: adım 10, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 10, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 10, 3 resimden 3.
    • Remove the two screws holding the speakers in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, remove the speaker.
  11. Toshiba Thrive Speakers Replacement: adım 11, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 11, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 11, 3 resimden 3.
    • Use the tweezers to help you remove the speaker wire from the clips holding them in place.
    • After removal place the left speaker on the side.
  12. Toshiba Thrive Speakers Replacement: adım 12, 3 resimden 1. Toshiba Thrive Speakers Replacement: adım 12, 3 resimden 2. Toshiba Thrive Speakers Replacement: adım 12, 3 resimden 3.
    • Use the tweezers again to help you remove the right speaker from its position.
    • Use a plastic opening tool to pull the connector connecting the speaker to the motherboard out of its port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ivan Williams
133 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 342
