Ana içeriğe geç
TotalPond Pond Pump Impeller Replacement
    1. TotalPond Pond Pump Impeller Replacement, Impeller: adım 1, 1 resimden 1.
      • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
      FixBot'a Sor
      Yorum Ekle
    2. TotalPond Pond Pump Impeller Replacement: adım 2, 1 resimden 1.
      • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
      FixBot'a Sor
      Yorum Ekle
    3. TotalPond Pond Pump Impeller Replacement: adım 3, 2 resimden 1. TotalPond Pond Pump Impeller Replacement: adım 3, 2 resimden 2.
      • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
      FixBot'a Sor
      Yorum Ekle
    4. TotalPond Pond Pump Impeller Replacement: adım 4, 2 resimden 1. TotalPond Pond Pump Impeller Replacement: adım 4, 2 resimden 2.
      • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicole Santana
612 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G6
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 3,788
