Ana içeriğe geç
TotalPond Pond Pump Impeller Rubber Stop Replacement
  1. TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: adım 1, 3 resimden 1. TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: adım 1, 3 resimden 2. TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: adım 1, 3 resimden 3.
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Rubber Stop Replacement: adım 2, 3 resimden 1. TotalPond Pond Pump Impeller Rubber Stop Replacement: adım 2, 3 resimden 2. TotalPond Pond Pump Impeller Rubber Stop Replacement: adım 2, 3 resimden 3.
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Rubber Stop Replacement: adım 3, 2 resimden 1. TotalPond Pond Pump Impeller Rubber Stop Replacement: adım 3, 2 resimden 2.
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicole Santana
597 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 662
