Ana içeriğe geç
TotalPond Pond Pump O-ring Replacement
    1. TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: adım 1, 3 resimden 1. TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: adım 1, 3 resimden 2. TotalPond Pond Pump O-ring Replacement, Inlet Screen Removal: adım 1, 3 resimden 3.
      • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
      FixBot'a Sor
      Yorum Ekle
    2. TotalPond Pond Pump O-ring Replacement, Impeller Assembly Detachment: adım 2, 2 resimden 1. TotalPond Pond Pump O-ring Replacement, Impeller Assembly Detachment: adım 2, 2 resimden 2.
      • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
      FixBot'a Sor
      Yorum Ekle
    3. TotalPond Pond Pump O-ring Replacement, Impeller Assembly Removal: adım 3, 1 resimden 1.
      • Carefully pull out the impeller. A magnetic pull should be felt.
      FixBot'a Sor
      Yorum Ekle
    4. TotalPond Pond Pump O-ring Replacement, O-Ring Removal: adım 4, 2 resimden 1. TotalPond Pond Pump O-ring Replacement, O-Ring Removal: adım 4, 2 resimden 2.
      • While holding the pump with one hand, pinch the O-ring and slide it upward with your free hand so that a portion of the ring is lifted.
      FixBot'a Sor
      Yorum Ekle
    5. TotalPond Pond Pump O-ring Replacement, O-Ring Removal continued: adım 5, 2 resimden 1. TotalPond Pond Pump O-ring Replacement, O-Ring Removal continued: adım 5, 2 resimden 2.
      • With one finger from the hand that is holding the pump, push the lifted portion of the ring forward until it is completely detached from the pump.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nicole Santana
612 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G6
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,087
