Ana içeriğe geç
Towel Bar Replacement
Neye ihtiyacın var
  1. Towel Bar Replacement, Towel Bar: adım 1, 1 resimden 1.
    • Measure the length of your current towel bar to make sure that your replacement towel bar is the correct size and will fit onto the same wall brackets.
  2. Towel Bar Replacement: adım 2, 2 resimden 1. Towel Bar Replacement: adım 2, 2 resimden 2.
    • In most cases, you can remove the towel bar by removing the screws underneath the bar holders.
  3. Towel Bar Replacement: adım 3, 1 resimden 1.
    • Remove the towel bar from the wall brackets.
  4. Towel Bar Replacement: adım 4, 1 resimden 1.
    • Place the new towel bar on top of the wall brackets and make sure that the bar is level.
  5. Towel Bar Replacement: adım 5, 2 resimden 1. Towel Bar Replacement: adım 5, 2 resimden 2.
    • Insert the screws into the holes beneath each bar holder.
  6. Towel Bar Replacement: adım 6, 2 resimden 1. Towel Bar Replacement: adım 6, 2 resimden 2.
    • After inserting the screws, screw in both sides firmly. Your new towel holder should now be good to use.
Sonuç
Muhammad Madni
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 53
Son 30 gün: 219
Her zaman: 6,658
