Ana içeriğe geç
Towel Bar Replacement
Neye ihtiyacın var
  1. Towel Bar Replacement, Towel Bar: adım 1, 1 resimden 1.
    • Measure the length of your current towel bar to make sure that your replacement towel bar is the correct size and will fit onto the same wall brackets.
    FixBot'a Sor
    Yorum Ekle
  2. Towel Bar Replacement: adım 2, 2 resimden 1. Towel Bar Replacement: adım 2, 2 resimden 2.
    • In most cases, you can remove the towel bar by removing the screws underneath the bar holders.
    FixBot'a Sor
    Yorum Ekle
  3. Towel Bar Replacement: adım 3, 1 resimden 1.
    • Remove the towel bar from the wall brackets.
    FixBot'a Sor
    Yorum Ekle
  4. Towel Bar Replacement: adım 4, 1 resimden 1.
    • Place the new towel bar on top of the wall brackets and make sure that the bar is level.
    FixBot'a Sor
    Yorum Ekle
  5. Towel Bar Replacement: adım 5, 2 resimden 1. Towel Bar Replacement: adım 5, 2 resimden 2.
    • Insert the screws into the holes beneath each bar holder.
    FixBot'a Sor
    Yorum Ekle
  6. Towel Bar Replacement: adım 6, 2 resimden 1. Towel Bar Replacement: adım 6, 2 resimden 2.
    • After inserting the screws, screw in both sides firmly. Your new towel holder should now be good to use.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Muhammad Madni
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 31
Son 30 gün: 217
Her zaman: 13,170
