Ana içeriğe geç
Toy Lightsaber Battery Replacement
Neye ihtiyacın var
  1. Toy Lightsaber Battery Replacement, Battery: adım 1, 3 resimden 1. Toy Lightsaber Battery Replacement, Battery: adım 1, 3 resimden 2. Toy Lightsaber Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: adım 2, 3 resimden 1. Toy Lightsaber Battery Replacement: adım 2, 3 resimden 2. Toy Lightsaber Battery Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: adım 3, 3 resimden 1. Toy Lightsaber Battery Replacement: adım 3, 3 resimden 2. Toy Lightsaber Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: adım 4, 3 resimden 1. Toy Lightsaber Battery Replacement: adım 4, 3 resimden 2. Toy Lightsaber Battery Replacement: adım 4, 3 resimden 3.
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: adım 5, 3 resimden 1. Toy Lightsaber Battery Replacement: adım 5, 3 resimden 2. Toy Lightsaber Battery Replacement: adım 5, 3 resimden 3.
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: adım 6, 3 resimden 1. Toy Lightsaber Battery Replacement: adım 6, 3 resimden 2. Toy Lightsaber Battery Replacement: adım 6, 3 resimden 3.
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zachary Adaes
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 52
Her zaman: 4,248
