Ana içeriğe geç
Toy Windmill Repair
Neye ihtiyacın var
  1. Toy Windmill Repair, Toy Windmill Repair: adım 1, 1 resimden 1.
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: adım 2, 1 resimden 1.
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: adım 3, 2 resimden 1. Toy Windmill Repair: adım 3, 2 resimden 2.
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: adım 4, 1 resimden 1.
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: adım 5, 1 resimden 1.
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: adım 6, 2 resimden 1. Toy Windmill Repair: adım 6, 2 resimden 2.
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
Sonuç
To reassemble your device, follow these instructions in order.
Karim Ladha
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 304
