Ana içeriğe geç
Toyota Corolla 2018 Brake Light Replacement
Neye ihtiyacın var
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: adım 1, 2 resimden 1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: adım 1, 2 resimden 2.
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: adım 2, 2 resimden 1. Toyota Corolla 2018 Brake Light Replacement: adım 2, 2 resimden 2.
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: adım 3, 2 resimden 1. Toyota Corolla 2018 Brake Light Replacement: adım 3, 2 resimden 2.
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: adım 4, 1 resimden 1.
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: adım 5, 1 resimden 1.
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: adım 6, 2 resimden 1. Toyota Corolla 2018 Brake Light Replacement: adım 6, 2 resimden 2.
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 81
Her zaman: 3,960
