Giriş
Use this guide to locate the fuse box and replace damaged fuses of Toyota Premio 2015. A blown wire can regularly be the guilty party for what is by all accounts bigger electrical issues. Figure out how to check your breakers and supplant any that need it.
Neye ihtiyacın var
Replace the blown fuse with a new replacement fuse of an appropriate amperage rating. The amperage rating can be found on the fuse box lid.
After you've replaced the fuse, start the car and check to see whether whatever the fuse was responsible for is now operational, such as your interior lighting.
Hope this guide has helped you replace any damaged fuse on your car. Please do routinely check your fuse box every 6 months.
3 farklı kişi bu kılavuzu tamamladı.
