Ana içeriğe geç
Toyota Yaris Key Battery Replacement
Neye ihtiyacın var
  1. Toyota Yaris Key Battery Replacement, Remove Key: adım 1, 3 resimden 1. Toyota Yaris Key Battery Replacement, Remove Key: adım 1, 3 resimden 2. Toyota Yaris Key Battery Replacement, Remove Key: adım 1, 3 resimden 3.
    • Release latch on back of key and pull from key ring to remove the backup metal key from the rest of the fob.
  2. Toyota Yaris Key Battery Replacement, Split key fob: adım 2, 2 resimden 1. Toyota Yaris Key Battery Replacement, Split key fob: adım 2, 2 resimden 2.
    • Using a knife or small flat blade screwdriver pry open the two halves of the key.
    • To avoid cosmetic damage start from the inside where the metal key was removed in the previous step.
  3. Toyota Yaris Key Battery Replacement, Remove battery cover: adım 3, 2 resimden 1. Toyota Yaris Key Battery Replacement, Remove battery cover: adım 3, 2 resimden 2.
    • Remove black circular cover, underneath is an O-ring and the battery.
  4. Toyota Yaris Key Battery Replacement, Replace Battery: adım 4, 1 resimden 1.
    • Battery can easily be removed and replaced. Using CR2025 3V battery, ensure writing is visible with battery installed.
    • To reassemble reverse steps, install battery cover, snap the two halves together and push metal key back into its receptacle (no tools required for reassembly).
Sonuç
Wieli
2.141 İtibar
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 40
Son 30 gün: 209
Her zaman: 1,558
