Ana içeriğe geç
Transforming High-Rise Pants into Low-Rise Style by Hand
Neye ihtiyacın var
  1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: adım 1, 2 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: adım 1, 2 resimden 2.
    • Begin by turning pants inside out and laying flat.
    FixBot'a Sor
    Yorum Ekle
  2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 2, 3 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 2, 3 resimden 2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 2, 3 resimden 3.
    • Line up the seams to match on both sides.
    • Mark where you would like the new bottom of your pants to sit.
    • Using a straight edge, mark a line going down from the initial mark down to the leg of the pants.
    FixBot'a Sor
    Yorum Ekle
  3. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 3, 3 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 3, 3 resimden 2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 3, 3 resimden 3.
    • After the guide lines have been drawn out, cut off the fabric marked off leaving roughly 1cm for seam allowance.
    FixBot'a Sor
    Yorum Ekle
  4. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 4, 2 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 4, 2 resimden 2.
    • Line up the fabric on both sides and pin together keeping the fabric in line.
    FixBot'a Sor
    Yorum Ekle
  5. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 5, 3 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 5, 3 resimden 2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 5, 3 resimden 3.
    • Thread your needle with a thread close to the color of the pants you are altering.
    • Tie the ends of the thread into a knot large enough to not go through the fabric being sewn.
    FixBot'a Sor
    Yorum Ekle
  6. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 6, 2 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 6, 2 resimden 2.
    • Insert the needle into the bottom of the marked line to begin your stitch.
    FixBot'a Sor
    Yorum Ekle
  7. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 7, 3 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 7, 3 resimden 2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 7, 3 resimden 3.
    • Pull thread through the fabric and reinsert leaving about 1mm in between.
    • Insert the needle on the back side of the fabric about 1mm away from the previous stitch.
    • Insert the needle back into the initial stitch to create a backstitch.
    FixBot'a Sor
    Yorum Ekle
  8. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 8, 3 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 8, 3 resimden 2. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 8, 3 resimden 3.
    • Continue backstitching all around the marked line.
    • Tie off the thread once you reach the end by tying a knot into the final stitch.
    FixBot'a Sor
    Yorum Ekle
  9. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 9, 2 resimden 1. Transforming High-Rise Pants into Low-Rise Style by Hand: adım 9, 2 resimden 2.
    • Flip pants right side out and enjoy your new low-rise pants!
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Addison Cavenee
169 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 740
