Ana içeriğe geç
Traxxas Ford Fiesta ST Rally Motor Replacement
Neye ihtiyacın var
  1. Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: adım 1, 3 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: adım 1, 3 resimden 2. Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: adım 1, 3 resimden 3.
    • Remove each of the four pins that hold the scale model shell by pulling them from their posts.
    • Remove the shell by lifting it off the chassis using your hands.
  2. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 2, 2 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 2, 2 resimden 2.
    • Remove the 3x6 mm screw holding the wire retainer in place using a 2.5 mm hex key.
    • Remove the wire retainer by lifting it off the chassis.
  3. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 3, 2 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 3, 2 resimden 2.
    • This guide was done without a battery present. Please remember to properly disconnect any batteries before this step as it could cause injury to you or damage to the device.
    • Disconnect both power cables attaching the electronic speed control to the motor.
  4. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 4, 2 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 4, 2 resimden 2.
    • Remove the 3x15 mm retaining bolt using the 3 mm hex key.
    • Remove the 3x6 mm flat head screw holding the motor plate in place with the 3 mm hex key.
  5. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 5, 2 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 5, 2 resimden 2.
    • Use the 2.5 mm hex key to remove the 3x6 mm screw for the gear cover.
    • To remove the cover, simply lift it up and off of the chassis.
    • During reassembly, ensure that the motor and gearing line up just how it is in the second photo for this step.
  6. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 6, 3 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 6, 3 resimden 2. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 6, 3 resimden 3.
    • Remove the motor by rotating and lifting it free from the chassis.
    • You may need to clean the area where the new motor will be to prevent the possibility of debris becoming a problem for a newly replaced engine.
  7. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 7, 3 resimden 1. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 7, 3 resimden 2. Traxxas Ford Fiesta ST Rally Motor Replacement: adım 7, 3 resimden 3.
    • Use the 2.5 mm hex key to loosen the 3x8 mm screws to remove the motor plate.
    • Use the 2 mm hex key to loosen the 3 mm grub screw enough to remove the pinion gear from the motor.
    • Slide the pinion gear right off the motor's external rod when loose enough.
    • Make sure to have the pinion gear in the exact same area as it was on the replaced motor in order to align with the device's gearing.
    • This process can also be used to put an even better motor in as a replacement during reassembly.
Sonuç
Follow these instructions in reverse order to reassemble your device using the new/functioning motor.
Joshua Bailey
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 520
