Ana içeriğe geç
Traxxas Summit Steering Assembly Servo Replacement
Neye ihtiyacın var
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: adım 1, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: adım 1, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: adım 1, 3 resimden 3.
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: adım 2, 2 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 2, 2 resimden 2.
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: adım 3, 2 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 3, 2 resimden 2.
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: adım 4, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 4, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 4, 3 resimden 3.
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: adım 5, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 5, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 5, 3 resimden 3.
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: adım 6, 2 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 6, 2 resimden 2.
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: adım 7, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 7, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 7, 3 resimden 3.
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: adım 8, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 8, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 8, 3 resimden 3.
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: adım 9, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 9, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 9, 3 resimden 3.
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: adım 10, 3 resimden 1. Traxxas Summit Steering Assembly Servo Replacement: adım 10, 3 resimden 2. Traxxas Summit Steering Assembly Servo Replacement: adım 10, 3 resimden 3.
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 2,321
