Ana içeriğe geç
Treblab HD77 Battery Replacement
Neye ihtiyacın var
  1. Treblab HD77 Battery Replacement, Surround: adım 1, 3 resimden 1. Treblab HD77 Battery Replacement, Surround: adım 1, 3 resimden 2. Treblab HD77 Battery Replacement, Surround: adım 1, 3 resimden 3.
    • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Treblab HD77 Battery Replacement: adım 2, 3 resimden 1. Treblab HD77 Battery Replacement: adım 2, 3 resimden 2. Treblab HD77 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
    • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
    FixBot'a Sor
    Yorum Ekle
  3. Treblab HD77 Battery Replacement: adım 3, 3 resimden 1. Treblab HD77 Battery Replacement: adım 3, 3 resimden 2. Treblab HD77 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
    • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
    • There is a layer of adhesive between the surround and the plastic housing it is resting on.
    FixBot'a Sor
    Yorum Ekle
  4. Treblab HD77 Battery Replacement, LED Light: adım 4, 3 resimden 1. Treblab HD77 Battery Replacement, LED Light: adım 4, 3 resimden 2. Treblab HD77 Battery Replacement, LED Light: adım 4, 3 resimden 3.
    • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
    • There are four points where adhesive is used to hold the LED light strip down.
    • Lift up the LED light strip from the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  5. Treblab HD77 Battery Replacement: adım 5, 3 resimden 1. Treblab HD77 Battery Replacement: adım 5, 3 resimden 2. Treblab HD77 Battery Replacement: adım 5, 3 resimden 3.
    • Flip the LED light strip upside down to see where the cord is plugged in.
    • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
    • The cord is very thin and lightweight so use caution when handling.
    FixBot'a Sor
    Yorum Ekle
  6. Treblab HD77 Battery Replacement, Battery: adım 6, 3 resimden 1. Treblab HD77 Battery Replacement, Battery: adım 6, 3 resimden 2. Treblab HD77 Battery Replacement, Battery: adım 6, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove all four 10mm screws that were exposed by removing the LED light strip.
    • Lift the plastic ring once all the screws have been removed.
    • The screws are very tiny and can fall inside the device if they are not handled carefully.
    • Repeat steps 1-6 for the opposite side.
    FixBot'a Sor
    Yorum Ekle
  7. Treblab HD77 Battery Replacement: adım 7, 2 resimden 1. Treblab HD77 Battery Replacement: adım 7, 2 resimden 2.
    • Slide the inner electronics casing out from the outer tubing encasing it.
    FixBot'a Sor
    Yorum Ekle
  8. Treblab HD77 Battery Replacement: adım 8, 2 resimden 1. Treblab HD77 Battery Replacement: adım 8, 2 resimden 2.
    • Unscrew the six 10mm screws holding the two halves of the electronics casing together using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Treblab HD77 Battery Replacement: adım 9, 3 resimden 1. Treblab HD77 Battery Replacement: adım 9, 3 resimden 2. Treblab HD77 Battery Replacement: adım 9, 3 resimden 3.
    • Insert the blade of a precision knife in between the edge of the rubber button cover and the extruded edges holding it in place.
    • Gently trace around the edge until you feel the cover beginning to loosen, and then slowly peel the cover up.
    • Be careful to not apply too much pressure with the blade, as there is a circuit board directly underneath the cover. There is also a layer of strong adhesive between the circuit board and the cover.
    FixBot'a Sor
    Yorum Ekle
  10. Treblab HD77 Battery Replacement: adım 10, 2 resimden 1. Treblab HD77 Battery Replacement: adım 10, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew the six 5mm screws holding the circuit board in place.
    FixBot'a Sor
    Yorum Ekle
  11. Treblab HD77 Battery Replacement: adım 11, 2 resimden 1. Treblab HD77 Battery Replacement: adım 11, 2 resimden 2.
    • Turn the speaker over to the side with the charging port dock, and gently pull the two halves apart by firmly grasping each half until they separate.
    FixBot'a Sor
    Yorum Ekle
  12. Treblab HD77 Battery Replacement: adım 12, 3 resimden 1. Treblab HD77 Battery Replacement: adım 12, 3 resimden 2. Treblab HD77 Battery Replacement: adım 12, 3 resimden 3.
    • Pinch the thin wire under the circuit board that connects it to the motherboard, and gently remove the wire from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  13. Treblab HD77 Battery Replacement: adım 13, 3 resimden 1. Treblab HD77 Battery Replacement: adım 13, 3 resimden 2. Treblab HD77 Battery Replacement: adım 13, 3 resimden 3.
    • Orient the speaker so the motherboard is on the bottom half, facing up, and the circuit board cutout is facing you.
    • Using your thumb and pointer finger, grip the plug connected to the large red and black wires just below the extruded tip, and gently lift until the plug comes out.
    FixBot'a Sor
    Yorum Ekle
  14. Treblab HD77 Battery Replacement: adım 14, 3 resimden 1. Treblab HD77 Battery Replacement: adım 14, 3 resimden 2. Treblab HD77 Battery Replacement: adım 14, 3 resimden 3.
    • Using your thumb and pointer finger, grip the plug connected to the smaller red and black wires just below the extruded tip, and gently lift until the plug comes out.
    FixBot'a Sor
    Yorum Ekle
  15. Treblab HD77 Battery Replacement: adım 15, 3 resimden 1. Treblab HD77 Battery Replacement: adım 15, 3 resimden 2. Treblab HD77 Battery Replacement: adım 15, 3 resimden 3.
    • The battery is located on the half without the motherboard and has a layer of foam surrounding it.
    • Lift the battery out of the shell using your thumb on the edge of the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Szabo
775 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 üyesi
UMASSD-BISWOKARMA-F25S3G5
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
any ideas what the batteries are?
Cheffrank Mach - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 314
