Ana içeriğe geç
Treblab HD77 LED Light Replacement
Neye ihtiyacın var
  1. Treblab HD77 LED Light Replacement, Surround: adım 1, 3 resimden 1. Treblab HD77 LED Light Replacement, Surround: adım 1, 3 resimden 2. Treblab HD77 LED Light Replacement, Surround: adım 1, 3 resimden 3.
    • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Treblab HD77 LED Light Replacement: adım 2, 3 resimden 1. Treblab HD77 LED Light Replacement: adım 2, 3 resimden 2. Treblab HD77 LED Light Replacement: adım 2, 3 resimden 3.
    • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
    • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
    FixBot'a Sor
    Yorum Ekle
  3. Treblab HD77 LED Light Replacement: adım 3, 3 resimden 1. Treblab HD77 LED Light Replacement: adım 3, 3 resimden 2. Treblab HD77 LED Light Replacement: adım 3, 3 resimden 3.
    • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
    • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
    • There is a layer of adhesive between the surround and the plastic housing it is resting on.
    FixBot'a Sor
    Yorum Ekle
  4. Treblab HD77 LED Light Replacement, LED Light: adım 4, 3 resimden 1. Treblab HD77 LED Light Replacement, LED Light: adım 4, 3 resimden 2. Treblab HD77 LED Light Replacement, LED Light: adım 4, 3 resimden 3.
    • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
    • There are four points where adhesive is used to hold the LED light strip down.
    • Lift up the LED light strip from the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  5. Treblab HD77 LED Light Replacement: adım 5, 3 resimden 1. Treblab HD77 LED Light Replacement: adım 5, 3 resimden 2. Treblab HD77 LED Light Replacement: adım 5, 3 resimden 3.
    • Flip the LED light strip upside down to see where the cord is plugged in.
    • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
    • The cord is very thin and lightweight so use caution when handling.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Matthew Szabo
775 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 üyesi
UMASSD-BISWOKARMA-F25S3G5
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 148
