Ana içeriğe geç
Trek 4300 Bicycle Front Wheel Replacement
    1. Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: adım 1, 2 resimden 1. Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: adım 1, 2 resimden 2.
      • Stand facing your bike and locate the brake calipers.
      • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
      FixBot'a Sor
      Yorum Ekle
    2. Trek 4300 Bicycle Front Wheel Replacement: adım 2, 2 resimden 1. Trek 4300 Bicycle Front Wheel Replacement: adım 2, 2 resimden 2.
      • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
      FixBot'a Sor
      Yorum Ekle
    3. Trek 4300 Bicycle Front Wheel Replacement: adım 3, 1 resimden 1.
      • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
      • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
      • The quick release lever does not need to be completely removed.
      • Note which side of the bike the quick release lever is on for proper reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Trek 4300 Bicycle Front Wheel Replacement: adım 4, 2 resimden 1. Trek 4300 Bicycle Front Wheel Replacement: adım 4, 2 resimden 2.
      • Pull the frame of the bike upwards to separate the front wheel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erin Ferguson
447 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 2,960
