Ana içeriğe geç
Trek 4300 Bicycle Kickstand Replacement
Neye ihtiyacın var
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: adım 1, 2 resimden 1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: adım 1, 2 resimden 2.
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: adım 2, 2 resimden 1. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: adım 2, 2 resimden 2.
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
Sonuç
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
500 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 2,810
