Ana içeriğe geç
Trek 4300 Bicycle Rear Wheel Replacement
  1. Trek 4300 Bicycle Rear Wheel Replacement, Rear Wheel: adım 1, 1 resimden 1.
    • Stand behind your bike straddling the rear wheel and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them towards one another.
  2. Trek 4300 Bicycle Rear Wheel Replacement: adım 2, 2 resimden 1. Trek 4300 Bicycle Rear Wheel Replacement: adım 2, 2 resimden 2.
    • Unhook the brake wire in the metal tube from the brake wire holder on the caliper in your left hand.
  3. Trek 4300 Bicycle Rear Wheel Replacement: adım 3, 2 resimden 1. Trek 4300 Bicycle Rear Wheel Replacement: adım 3, 2 resimden 2.
    • Find the quick release lever located on the wheel's fork.
    • Open the leaver 180 degrees from the locked position.
    • Spin the lever counterclockwise a few turns to loosen the pin while holding the opposite of the pin.
  4. Trek 4300 Bicycle Rear Wheel Replacement: adım 4, 2 resimden 1. Trek 4300 Bicycle Rear Wheel Replacement: adım 4, 2 resimden 2.
    • Pull the bike frame upward off the wheel fork to separate it from the rear wheel.
    • Remove the bottom chain from around the rear cassette on the wheel.
  5. Trek 4300 Bicycle Rear Wheel Replacement: adım 5, 1 resimden 1.
    • In reassembly, lay the top chain on the lowest gear on the rear cassette. Then follow the steps in reverse order beginning with step 3.
Sonuç
To reassemble your device, lay the top chain on the smallest gear of the rear cassette and then follow the steps in reverse order beginning with step 3.
Bir başkası bu kılavuzu tamamladı.
Emily OConnor
500 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 üyesi
CLEM-BENSON-F14S3G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 3,305
