Giriş
There are many reasons why a bicycle tire may become flat. Often it is caused by running over debris or pumping up the tires too much. Punctures can create small holes that can cause slow leaks whereas tires pumped up too much will cause the inner tube to burst. When anything like this occurs, the inner tube needs to be replaced. This guide will demonstrate the process required to fix a worn or punctured bike tube on a Trek 800 model bicycle with no prior experience. After finishing, your bicycle will be ready to ride!
Pull the tire and the rim off of the bike.
Pinch the tire and separate from the rim.
I remember getting the tire off the rim was difficult. There are special levers to help pull off the tire. You use three of them to pull the rim off, inserting one after the other and sliding them to the side.
Pull out the punctured tube from the tire and replace with the new tube.
Alternatively you might want to patch your tube's puncture.
You forgot to instruct them to inspect the inside of the tire for anything that would puncture the new tube as well as inspecting the rim for anything.
If all of your steps were completed correctly you should be free to ride. Enjoy.
Bir Yorum
Thanks for providing these instructions. But I think the most difficult step (getting the tire off the rim) should be explained in more detail.
