Ana içeriğe geç
Trek 820 Handlebars Replacement
Neye ihtiyacın var
    1. Trek 820 Handlebars Replacement, Handlebar and stem: adım 1, 2 resimden 1. Trek 820 Handlebars Replacement, Handlebar and stem: adım 1, 2 resimden 2.
      • Use a 3/16" Allen Wrench to remove the silver cap.
      FixBot'a Sor
      Yorum Ekle
    2. Trek 820 Handlebars Replacement: adım 2, 1 resimden 1.
      • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
      FixBot'a Sor
      Yorum Ekle
    3. Trek 820 Handlebars Replacement: adım 3, 2 resimden 1. Trek 820 Handlebars Replacement: adım 3, 2 resimden 2.
      • Remove the handlebar by lifting vertically away from the frame.
      • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
      FixBot'a Sor
      Yorum Ekle
    4. Trek 820 Handlebars Replacement: adım 4, 2 resimden 1. Trek 820 Handlebars Replacement: adım 4, 2 resimden 2.
      • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
      • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
      FixBot'a Sor
      Yorum Ekle
    5. Trek 820 Handlebars Replacement: adım 5, 1 resimden 1.
      • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
      • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
      • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kaveh Karimiyanha
822 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G1
5 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 74
Her zaman: 6,907
