Ana içeriğe geç
Trek 820 Tail Light Mounting Bracket Replacement
Neye ihtiyacın var
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: adım 1, 1 resimden 1.
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: adım 2, 1 resimden 1.
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: adım 3, 2 resimden 1. Trek 820 Tail Light Mounting Bracket Replacement: adım 3, 2 resimden 2.
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: adım 4, 2 resimden 1. Trek 820 Tail Light Mounting Bracket Replacement: adım 4, 2 resimden 2.
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Sonuç
Kaveh Karimiyanha
813 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G1
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,140
