Ana içeriğe geç
Trek FX2 Fitness Bike Saddle Replacement
Neye ihtiyacın var
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: adım 1, 3 resimden 1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: adım 1, 3 resimden 2. Trek FX2 Fitness Bike Saddle Replacement, Saddle: adım 1, 3 resimden 3.
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: adım 2, 2 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 2, 2 resimden 2.
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: adım 3, 2 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 3, 2 resimden 2.
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: adım 4, 3 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 4, 3 resimden 2. Trek FX2 Fitness Bike Saddle Replacement: adım 4, 3 resimden 3.
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: adım 5, 2 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 5, 2 resimden 2.
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: adım 6, 3 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 6, 3 resimden 2. Trek FX2 Fitness Bike Saddle Replacement: adım 6, 3 resimden 3.
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: adım 7, 3 resimden 1. Trek FX2 Fitness Bike Saddle Replacement: adım 7, 3 resimden 2. Trek FX2 Fitness Bike Saddle Replacement: adım 7, 3 resimden 3.
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: adım 8, 1 resimden 1.
    • Sit on the seat to check its angle and stability.
Sonuç
Test out the bike seat, and adjust accordingly.
David Fong
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S4G6
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 27
Her zaman: 110
