Ana içeriğe geç
Triace A310 Brake Cable Replacement
Neye ihtiyacın var
  1. Triace A310 Brake Cable Replacement, Brake Cable: adım 1, 2 resimden 1. Triace A310 Brake Cable Replacement, Brake Cable: adım 1, 2 resimden 2.
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: adım 2, 3 resimden 1. Triace A310 Brake Cable Replacement: adım 2, 3 resimden 2. Triace A310 Brake Cable Replacement: adım 2, 3 resimden 3.
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: adım 3, 2 resimden 1. Triace A310 Brake Cable Replacement: adım 3, 2 resimden 2.
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: adım 4, 3 resimden 1. Triace A310 Brake Cable Replacement: adım 4, 3 resimden 2. Triace A310 Brake Cable Replacement: adım 4, 3 resimden 3.
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: adım 5, 3 resimden 1. Triace A310 Brake Cable Replacement: adım 5, 3 resimden 2. Triace A310 Brake Cable Replacement: adım 5, 3 resimden 3.
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
Sonuç
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
340 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G37
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 353
