Ana içeriğe geç
Triace A310 Disk Brake Replacement
Neye ihtiyacın var
  1. Triace A310 Disk Brake Replacement, Tire: adım 1, 1 resimden 1.
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: adım 2, 2 resimden 1. Triace A310 Disk Brake Replacement: adım 2, 2 resimden 2.
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: adım 3, 2 resimden 1. Triace A310 Disk Brake Replacement: adım 3, 2 resimden 2.
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: adım 4, 1 resimden 1.
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: adım 5, 3 resimden 1. Triace A310 Disk Brake Replacement: adım 5, 3 resimden 2. Triace A310 Disk Brake Replacement: adım 5, 3 resimden 3.
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: adım 6, 2 resimden 1. Triace A310 Disk Brake Replacement: adım 6, 2 resimden 2.
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Sonuç
Daniel
222 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G37
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 649
