Ana içeriğe geç
Tribit XSound Go TS-BTS20 Passive Radiator Replacement
Neye ihtiyacın var
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: adım 1, 2 resimden 1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: adım 1, 2 resimden 2.
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: adım 2, 1 resimden 1.
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: adım 3, 2 resimden 1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: adım 3, 2 resimden 2.
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: adım 4, 1 resimden 1.
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: adım 5, 1 resimden 1.
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 64
