Ana içeriğe geç
Trio AXS 3G Back Case Replacement
Neye ihtiyacın var
  1. Trio AXS 3G Back Case Replacement, Back Case: adım 1, 1 resimden 1.
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Back Case Replacement: adım 2, 2 resimden 1. Trio AXS 3G Back Case Replacement: adım 2, 2 resimden 2.
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Back Case Replacement: adım 3, 1 resimden 1.
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
Sonuç
Javoy Ross
316 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 325
