Ana içeriğe geç
Trio AXS 3G Camera Replacement
Neye ihtiyacın var
    1. Trio AXS 3G Camera Replacement, Back Case: adım 1, 1 resimden 1.
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      FixBot'a Sor
      Yorum Ekle
    2. Trio AXS 3G Camera Replacement: adım 2, 2 resimden 1. Trio AXS 3G Camera Replacement: adım 2, 2 resimden 2.
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      FixBot'a Sor
      Yorum Ekle
    3. Trio AXS 3G Camera Replacement: adım 3, 1 resimden 1.
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      FixBot'a Sor
      Yorum Ekle
    1. Trio AXS 3G Camera Replacement, Camera: adım 4, 2 resimden 1. Trio AXS 3G Camera Replacement, Camera: adım 4, 2 resimden 2.
      • Unscrew 5 #000 4 mm and 3 mm screws around the strip.
      FixBot'a Sor
      Yorum Ekle
    2. Trio AXS 3G Camera Replacement: adım 5, 1 resimden 1.
      • Undo the tape on top of the connector from the camera to motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Trio AXS 3G Camera Replacement: adım 6, 1 resimden 1.
      • Slightly lift up the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Trio AXS 3G Camera Replacement: adım 7, 2 resimden 1. Trio AXS 3G Camera Replacement: adım 7, 2 resimden 2.
      • Disconnect the camera from the motherboard on the topside and pull the camera strip out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Javoy Ross
316 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
Where can I get the camera?
Amanda Springsteen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 451
