Ana içeriğe geç
Trio STEALTH-9 Back Cover Replacement
Neye ihtiyacın var
    1. Trio STEALTH-9 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
      • Remove the two Phillips #00 screws on the side of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Trio STEALTH-9 Back Cover Replacement: adım 2, 1 resimden 1.
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Trio STEALTH-9 Back Cover Replacement: adım 3, 1 resimden 1.
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      FixBot'a Sor
      Yorum Ekle
    4. Trio STEALTH-9 Back Cover Replacement: adım 4, 1 resimden 1.
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 farklı kişi bu kılavuzu tamamladı.
Mei Liang
228 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-5, Shirley Winter 2015 Clemson, Team 15-5, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G5
4 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
Tengo.una y costo tiene el.displey
eliehtmaria - Yanıt Paylaş
Deseo.saber el.c
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 1,550
