Giriş
Here, you will be working with live wires on a power source! Be very careful when you desolder them, and make sure you don't let the leads touch!
Neye ihtiyacın var
To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
Apply heat and solder to each lead individually.
Remove any excess solder if flooding occurs.
To replace the battery, you must re-solder the leads on the battery into the motherboard. You MUST make sure that the leads were in the correct order as when you started.
Bir Yorum
Is it possible that the wiring to the battery just became loose and I could use these same directions and reconnect or solder (or do both?) The existing battery ?
