Ana içeriğe geç
Trio STEALTH-9 Camera Replacement
Neye ihtiyacın var
    1. Trio STEALTH-9 Camera Replacement, Back Cover: adım 1, 1 resimden 1.
      • Remove the two Phillips #00 screws on the side of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Trio STEALTH-9 Camera Replacement: adım 2, 1 resimden 1.
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Trio STEALTH-9 Camera Replacement: adım 3, 1 resimden 1.
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      FixBot'a Sor
      Yorum Ekle
    4. Trio STEALTH-9 Camera Replacement: adım 4, 1 resimden 1.
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      FixBot'a Sor
      Yorum Ekle
    1. Trio STEALTH-9 Camera Replacement, Camera: adım 5, 2 resimden 1. Trio STEALTH-9 Camera Replacement, Camera: adım 5, 2 resimden 2.
      • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Trio STEALTH-9 Camera Replacement: adım 6, 2 resimden 1. Trio STEALTH-9 Camera Replacement: adım 6, 2 resimden 2.
      • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
      FixBot'a Sor
      Yorum Ekle
    3. Trio STEALTH-9 Camera Replacement: adım 7, 2 resimden 1. Trio STEALTH-9 Camera Replacement: adım 7, 2 resimden 2.
      • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
      • Remove the camera from the frame and replace as needed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
[deleted]
415 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 432
