Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the two 1.2 mm Phillips #0 screws found at the side by the power button. Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  3. Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  4. Remove the speakers by using your hand to entirely disconnect the back cover. Remove the speakers by using your hand to entirely disconnect the back cover. Remove the speakers by using your hand to entirely disconnect the back cover.
    • Remove the speakers by using your hand to entirely disconnect the back cover.
Sonuç
Thomas Lichtenberger
438 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G4
3 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
Her zaman: 574
