Ana içeriğe geç
Trio Stealth G2 Hype Back Panel Replacement
Neye ihtiyacın var
  1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Back Panel Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Back Panel Replacement: adım 3, 3 resimden 1. Trio Stealth G2 Hype Back Panel Replacement: adım 3, 3 resimden 2. Trio Stealth G2 Hype Back Panel Replacement: adım 3, 3 resimden 3.
    • Remove the speakers by using your hand to entirely disconnect the back cover.
Sonuç
Thomas Lichtenberger
459 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 688
