Ana içeriğe geç
Trio Stealth G2 Hype Speakers Replacement
Neye ihtiyacın var
  1. Trio Stealth G2 Hype Speakers Replacement, Back Panel: adım 1, 2 resimden 1. Trio Stealth G2 Hype Speakers Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Speakers Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Speakers Replacement: adım 3, 3 resimden 1. Trio Stealth G2 Hype Speakers Replacement: adım 3, 3 resimden 2. Trio Stealth G2 Hype Speakers Replacement: adım 3, 3 resimden 3.
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Speakers Replacement, Speakers: adım 4, 2 resimden 1. Trio Stealth G2 Hype Speakers Replacement, Speakers: adım 4, 2 resimden 2.
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Speakers Replacement: adım 5, 1 resimden 1.
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
Sonuç
Thomas Lichtenberger
459 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 244
