Ana içeriğe geç
Trio Stealth G4 Volume Buttons Replacement
Neye ihtiyacın var
  1. Trio Stealth G4 Volume Buttons Replacement, Back Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
  2. Trio Stealth G4 Volume Buttons Replacement: adım 2, 2 resimden 1. Trio Stealth G4 Volume Buttons Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
  3. Trio Stealth G4 Volume Buttons Replacement: adım 3, 1 resimden 1.
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
  4. Trio Stealth G4 Volume Buttons Replacement: adım 4, 2 resimden 1. Trio Stealth G4 Volume Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the back panel from the rest of the tablet and set it aside.
  5. Trio Stealth G4 Volume Buttons Replacement: adım 5, 1 resimden 1.
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
  6. Trio Stealth G4 Volume Buttons Replacement, Volume Buttons: adım 6, 1 resimden 1.
    • Remove the yellow tape covering the set of wires located near the upper right corner of the battery.
  7. Trio Stealth G4 Volume Buttons Replacement: adım 7, 3 resimden 1. Trio Stealth G4 Volume Buttons Replacement: adım 7, 3 resimden 2. Trio Stealth G4 Volume Buttons Replacement: adım 7, 3 resimden 3.
    • Wedge a spudger underneath the black flap on the zero insertion force (ZIF) connector and flip it up.
    • Once the flap is up, use your fingers to disconnect the end of the ribbon wire from the connector.
  8. Trio Stealth G4 Volume Buttons Replacement: adım 8, 3 resimden 1. Trio Stealth G4 Volume Buttons Replacement: adım 8, 3 resimden 2. Trio Stealth G4 Volume Buttons Replacement: adım 8, 3 resimden 3.
    • Use your fingers to carefully peel the volume sensors away from the top of the plastic L-shaped speaker housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matt Arnold
607 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S4G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 353
