Ana içeriğe geç
Trio Stealth Pro 9.7" Rear/Front Camera Replacement
Neye ihtiyacın var
  1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement, Rear/Front Camera: adım 1, 1 resimden 1.
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 2, 2 resimden 1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 3, 3 resimden 1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 3, 3 resimden 2. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 3, 3 resimden 3.
    • Use plastic opening tool to lift up black clip.
    • Gently pull out flex cable.
  4. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 4, 1 resimden 1.
    • Remove 3 silver 4 cm Phillips screws holding down black plastic speaker cover.
    • Gently pull up on plastic to uncover clip connected to the camera.
  5. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 5, 2 resimden 1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: adım 5, 2 resimden 2.
    • Use the tweezers and gently lift up on the clip.
    • Remove the front/rear camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Edward Insogna
626 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Miles Spring 2015 UMass Dartmouth, Team 1-3, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 150
