Ana içeriğe geç
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: adım 1, 1 resimden 1.
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: adım 2, 1 resimden 1.
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: adım 3, 1 resimden 1.
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Coleman
643 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 431
