Ana içeriğe geç
Giriş
A common issue with smart devices is a faulty battery. This guide goes through the steps needed to replace the battery of a Trio Stealth-Mini.
  1. Locate the indentation at the bottom of the device. Locate the indentation at the bottom of the device.
    • Locate the indentation at the bottom of the device.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device.
    • Pull on the indentation and take off the casing of the device.
  4. Remove the faulty battery and insert a replacement in its slot. Remove the faulty battery and insert a replacement in its slot.
    • Remove the faulty battery and insert a replacement in its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Damon Myers
124 İtibar
1 Kılavuz yazıldı
Takım
IUPUI, Team S1-G1, Harley Spring 2018 IUPUI, Team S1-G1, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G1
7 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where can I get a battery for this device
Rakeida - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 11
Her zaman: 105
