Ana içeriğe geç
Trio Stealth-Mini Screen Replacement
Neye ihtiyacın var
  1. Trio Stealth-Mini Screen Replacement, Battery: adım 1, 2 resimden 1. Trio Stealth-Mini Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the indentation at the bottom of the device.
  2. Trio Stealth-Mini Screen Replacement: adım 2, 3 resimden 1. Trio Stealth-Mini Screen Replacement: adım 2, 3 resimden 2. Trio Stealth-Mini Screen Replacement: adım 2, 3 resimden 3.
    • Pull on the indentation and take off the casing of the device.
  3. Trio Stealth-Mini Screen Replacement: adım 3, 2 resimden 1. Trio Stealth-Mini Screen Replacement: adım 3, 2 resimden 2.
    • Remove the faulty battery and insert a replacement in its slot.
  4. Trio Stealth-Mini Screen Replacement, Screen: adım 4, 1 resimden 1.
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Trio Stealth-Mini Screen Replacement: adım 5, 1 resimden 1.
    • Remove inner casing exposing the motherboard.
  6. Trio Stealth-Mini Screen Replacement: adım 6, 2 resimden 1. Trio Stealth-Mini Screen Replacement: adım 6, 2 resimden 2.
    • Remove speakers by peeling back yelllow tape.
  7. Trio Stealth-Mini Screen Replacement: adım 7, 1 resimden 1.
    • Remove ribbon cable on top of motherboard.
  8. Trio Stealth-Mini Screen Replacement: adım 8, 1 resimden 1.
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  9. Trio Stealth-Mini Screen Replacement: adım 9, 1 resimden 1.
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  10. Trio Stealth-Mini Screen Replacement: adım 10, 1 resimden 1.
    • Verify that all screws are detached from screen.
  11. Trio Stealth-Mini Screen Replacement: adım 11, 1 resimden 1.
    • Detach screen from main assembly.
Sonuç
Stewart Jenkins
207 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Harley Spring 2018 IUPUI, Team S1-G1, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G1
7 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 230
