Ana içeriğe geç
Tristar Handmixer Gears Replacement
Neye ihtiyacın var
  1. Tristar Handmixer Gears Replacement, Gears: adım 1, 3 resimden 1. Tristar Handmixer Gears Replacement, Gears: adım 1, 3 resimden 2. Tristar Handmixer Gears Replacement, Gears: adım 1, 3 resimden 3.
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: adım 2, 3 resimden 1. Tristar Handmixer Gears Replacement: adım 2, 3 resimden 2. Tristar Handmixer Gears Replacement: adım 2, 3 resimden 3.
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: adım 3, 3 resimden 1. Tristar Handmixer Gears Replacement: adım 3, 3 resimden 2. Tristar Handmixer Gears Replacement: adım 3, 3 resimden 3.
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: adım 4, 2 resimden 1. Tristar Handmixer Gears Replacement: adım 4, 2 resimden 2.
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: adım 5, 1 resimden 1.
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
where can I get replacement gears from?
lanz - Yanıt
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 1,488
