Ana içeriğe geç
Tritton Kunai Headphone Jack Replacement
Neye ihtiyacın var
    • Cut off the bad jack with 1 inch of wire. You need a bit of wire because you will need to test which color wire corresponds to which section on the jack. Every device uses different color wires, so testing your individual device will insure accurate first try connections.
    • Trim the black wire cover back 1 inch to expose the 4 wires and nylon string inside. Red = mic = sleeve. Blue = right headphone = ring 1. White = left headphone = tip. Copper = ground = ring 2.
    • Trim the small wires (red, blue, white) by burning the tips of the wires. Seperate each wire and burn them back about 1/4 inch. Then use a knife or razor to scrape the tips clean. The copper wire strands will be seperated and exposed already. Collect all the copper strands and twist them together.
    • Tin the wires by heating the wire with the soldering iron and applying the solder wire. Apply the soldering wire between the soldering wire and wire to get it started. Then continue to apply solder to the wire. Tin all 4 wires.
    • Tinning all connection points will help make soldering the wires to the contact points on the new jack easier.
Sonuç
Test your mic and sound and enjoy a job well done.
Peter Yang
101 İtibar
1 Kılavuz yazıldı
2 Yorum
do you have any pictures?
Kodak Chino - Yanıt
Thanks for the wiring guide - helped me out of a spot today :)
Grant Donachie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,399
