Ana içeriğe geç
Tritton Kunai Left Speaker Replacement
Neye ihtiyacın var
  1. Tritton Kunai Left Speaker Replacement, Left Speaker: adım 1, 2 resimden 1. Tritton Kunai Left Speaker Replacement, Left Speaker: adım 1, 2 resimden 2.
    • Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Tritton Kunai Left Speaker Replacement: adım 2, 2 resimden 1. Tritton Kunai Left Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
    • Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Tritton Kunai Left Speaker Replacement: adım 3, 2 resimden 1. Tritton Kunai Left Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Tritton Kunai Left Speaker Replacement: adım 4, 2 resimden 1. Tritton Kunai Left Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the six 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Tritton Kunai Left Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the red and white wires from the 16 Ohm speaker.
  6. Tritton Kunai Left Speaker Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Squeeze the tip of the tweezers into the gap between the speaker and the speaker case.
    • Remove the glue holding the speaker in place by scraping the glue with the tip of the tweezers.
  7. Tritton Kunai Left Speaker Replacement: adım 7, 2 resimden 1. Tritton Kunai Left Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the speaker from its circular shaped slot.
    • Apply glue to the sides of your new 16 Ohm speaker.
  8. Tritton Kunai Left Speaker Replacement: adım 9, 2 resimden 1. Tritton Kunai Left Speaker Replacement: adım 9, 2 resimden 2.
    • Insert your new speaker into the circular shaped slot located on the speaker cover.
  9. Tritton Kunai Left Speaker Replacement: adım 10, 1 resimden 1.
    • Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far left terminal, while the white wire is to be soldered to the far right terminal.
    • Here is iFixit's soldering guide.
    • Solder with caution and try not to burn yourself.
Sonuç
To reassemble your device, follow steps 1 through 4 in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Elias El Tom
338 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,412
