Giriş
With the diffused application of Face ID on iPhone X – 11 series, Face ID failure also appears at a high frequency. As our previous Face ID teardown video has introduced, Face ID can be easily damaged and hardly repaired. If the problem is related to the flex cable, then it’s simple. However, based on statistics of REWA chip-level motherboard repair service, Face ID failure is caused by damage of the Flood illuminator/Dot Projector in most cases, which can not be repaired.
Videoya Genel Bakış
The phone keeps sending messages: ‘move iPhone a little lower/higher’ during the setting up process of Face ID. Based on REWA exclusive repair tricks, let’s start with the Flood Illuminator.
In our daily repair work, we can test the Proximity Sensor and the Ambient Light Sensor to confirm whether the Flood Illuminator is working normally.
Let’s make a phone call to confirm whether the Proximity Sensor is working. The Proximity Sensor works normally.
Next, test the Ambient Light Sensor. The Ambient Light Sensor is also working normally.
Judging by this, the Face ID failure is not caused by Flood Illuminator.
Let’s move on to the next step of Face ID troubleshooting – test the front camera parts.
Open the camera app and swipe to Portrait Mode. The background is not blurred, which is abnormal.
At the Portrait Mode, there is no flashing red light from the Dot Projector.
We can confirm now that the Dot Projector has malfunctioned.
This is the fault and the problem cannot be fixed.
- To fully understand Face ID, you can also check Face ID Teardown here.
24 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Wieder mal traurig zu sehen was apple alles tut um die reperatur zu verteuern und drittreperaturshops zu blockieren.
how do you test the infrared camera? my face id is not working but everything chek out I thought the problem is the dot projector but it is working
The title is How to fix and at the and it says can not be fixed :)))
Here is a new method for fixing the dot projector. Apparently you may need multiple tag on flexes for it to work
https://www.youtube.com/watch?v=OnFCp9tt...
