Ana içeriğe geç
Troy-Bilt TB675 EC Air Filter Replacement
Neye ihtiyacın var
  1. Troy-Bilt TB675 EC Air Filter Replacement, Air Filter: adım 1, 1 resimden 1.
    • Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
  2. Troy-Bilt TB675 EC Air Filter Replacement, Remove the air filter that lays beneath the housing you removed in step 1: adım 2, 1 resimden 1.
    • Remove the air filter that lays beneath the housing you removed in step 1.
    • It is good practice to inspect your air filter for tears or other defects. If defects are found it is best to replace the air filter rather than to clean it.
  3. Troy-Bilt TB675 EC Air Filter Replacement: adım 3, 1 resimden 1.
    • Clean the air filter thoroughly by spraying compressed air through the filter.
    • Be sure to spray the compressed air away from you in order to prevent injury.
  4. Troy-Bilt TB675 EC Air Filter Replacement: adım 4, 2 resimden 1. Troy-Bilt TB675 EC Air Filter Replacement: adım 4, 2 resimden 2.
    • Wipe all oil and water residue around the air filter casing with a paper towel or rag.
  5. Troy-Bilt TB675 EC Air Filter Replacement: adım 5, 1 resimden 1.
    • Place the air filter and air filter casing back in its original position.
    • Be sure the air filter and housing are lined up correctly.
  6. Troy-Bilt TB675 EC Air Filter Replacement: adım 6, 1 resimden 1.
    • Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
Bitiş Çizgisi
Brian Hall
110 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-10, Donnelly Fall 2014 USF Tampa, Team 1-10, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G10
1 Üye
1 Kılavuz yazıldı
Bir Yorum
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
Mark Henry Cooney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 2,371
