Ana içeriğe geç
Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement
Neye ihtiyacın var
  1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Panel: adım 1, 1 resimden 1.
    • Flip the keyboard over.
  2. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 2, 2 resimden 1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 2, 2 resimden 2.
    • Remove the three JIS #1 screws from the back cover.
  3. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 3, 2 resimden 1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 3, 2 resimden 2.
    • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  4. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 4, 1 resimden 1.
    • Pull apart the two parts of the panel to expose the motherboard and keys.
  5. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Keys: adım 5, 2 resimden 1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Keys: adım 5, 2 resimden 2.
    • Use a plastic opening tool to pry off every key.
  6. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 6, 3 resimden 1. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 6, 3 resimden 2. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement: adım 6, 3 resimden 3.
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
    • Pull these keys to the side and up.
  7. Tt Esports Poseidon Z RGB KB-PZR-KLBRUS-06 Led Lights Replacement, Led Lights: adım 7, 1 resimden 1.
    • Since the LED lights are connected to every key, you will need to replace this whole part.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 532
