Ana içeriğe geç
Tuck Lock Clasp Replacement
Neye ihtiyacın var
    1. Tuck Lock Clasp Replacement, Tuck Lock Clasp: adım 1, 1 resimden 1.
      • Locate broken tuck lock clasp.
      FixBot'a Sor
      Yorum Ekle
    2. Tuck Lock Clasp Replacement: adım 2, 3 resimden 1. Tuck Lock Clasp Replacement: adım 2, 3 resimden 2. Tuck Lock Clasp Replacement: adım 2, 3 resimden 3.
      • Grab the broken clasp and flip it so that you can see the heads of the screws.
      FixBot'a Sor
      Yorum Ekle
    3. Tuck Lock Clasp Replacement: adım 3, 2 resimden 1. Tuck Lock Clasp Replacement: adım 3, 2 resimden 2.
      • Using a Phillips screwdriver, remove the screws.
      FixBot'a Sor
      Yorum Ekle
    4. Tuck Lock Clasp Replacement: adım 4, 2 resimden 1. Tuck Lock Clasp Replacement: adım 4, 2 resimden 2.
      • Place one hand holding on to the strap and another grabbing the clasp.
      • Pull the strap and clasp away from each other until completely separated.
      FixBot'a Sor
      Yorum Ekle
    5. Tuck Lock Clasp Replacement: adım 5, 3 resimden 1. Tuck Lock Clasp Replacement: adım 5, 3 resimden 2. Tuck Lock Clasp Replacement: adım 5, 3 resimden 3.
      • Push the new clasp onto the strap.
      • Ensure that the screw holes of the strap and clasp are lined up with each other.
      FixBot'a Sor
      Yorum Ekle
    6. Tuck Lock Clasp Replacement: adım 6, 3 resimden 1. Tuck Lock Clasp Replacement: adım 6, 3 resimden 2. Tuck Lock Clasp Replacement: adım 6, 3 resimden 3.
      • Reinsert the screws into the holes.
      FixBot'a Sor
      Yorum Ekle
    7. Tuck Lock Clasp Replacement: adım 7, 2 resimden 1. Tuck Lock Clasp Replacement: adım 7, 2 resimden 2.
      • Tighten the screws using a Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Tuck Lock Clasp Replacement: adım 8, 1 resimden 1.
      • Your tuck lock clasp has now been replaced!
      FixBot'a Sor
      Yorum Ekle
    9. Tuck Lock Clasp Replacement: adım 9, 3 resimden 1. Tuck Lock Clasp Replacement: adım 9, 3 resimden 2. Tuck Lock Clasp Replacement: adım 9, 3 resimden 3.
      • Ensure your replacement tuck lock clasp works by inserting the tuck lock clasp into the base plate.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Dawson V
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-7, Morris Fall 2025 UC Davis, Team 2-7, Morris Fall 2025 üyesi
UCD-MORRIS-F25S2G7
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 323
