Ana içeriğe geç
Tungsten E Battery Replacement
Neye ihtiyacın var
  1. Tungsten E Battery Replacement, Battery: adım 1, 1 resimden 1.
  2. Tungsten E Battery Replacement: adım 2, 1 resimden 1.
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Tungsten E Battery Replacement: adım 3, 1 resimden 1.
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  4. Tungsten E Battery Replacement: adım 4, 1 resimden 1.
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  5. Tungsten E Battery Replacement: adım 5, 1 resimden 1.
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kathleen Hix
49 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G22
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 6,837
