Ana içeriğe geç
Tungsten T3 Battery Replacement
Neye ihtiyacın var
  1. Tungsten T3 Battery Replacement, Battery: adım 1, 2 resimden 1. Tungsten T3 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two Phillips #00 screws on either side of the device, on the sliding panel.
    FixBot'a Sor
    Yorum Ekle
  2. Tungsten T3 Battery Replacement: adım 2, 3 resimden 1. Tungsten T3 Battery Replacement: adım 2, 3 resimden 2. Tungsten T3 Battery Replacement: adım 2, 3 resimden 3.
    • Slide out the function panel.
    • Insert a paper clip into the two marked small holes on the back and push downwards while pulling the function panel gently.
    • The connector for the buttons will be revealed.
    FixBot'a Sor
    Yorum Ekle
  3. Tungsten T3 Battery Replacement: adım 3, 3 resimden 1. Tungsten T3 Battery Replacement: adım 3, 3 resimden 2. Tungsten T3 Battery Replacement: adım 3, 3 resimden 3.
    • Gently remove the function panel from the device.
    • Be careful - it's still connected by the button cable. Peel the cable from the device carefully with a spudger - it is attached with a little bit of adhesive.
    • Carefully remove the connector and set the panel aside.
    FixBot'a Sor
    Yorum Ekle
  4. Tungsten T3 Battery Replacement: adım 4, 2 resimden 1. Tungsten T3 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #00 screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Tungsten T3 Battery Replacement: adım 5, 3 resimden 1. Tungsten T3 Battery Replacement: adım 5, 3 resimden 2. Tungsten T3 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the two small Phillips #00 screws at the other end of the device.
    • A small metal part will fall out of the device from the other side. Keep hold of this - you won't be able to put these screws back in without it.
    FixBot'a Sor
    Yorum Ekle
  6. Tungsten T3 Battery Replacement: adım 6, 3 resimden 1. Tungsten T3 Battery Replacement: adım 6, 3 resimden 2. Tungsten T3 Battery Replacement: adım 6, 3 resimden 3.
    • Using a spudger, gently separate the back casing from the rest of the device.
    • Be careful - the back casing contains the battery, which is connected by a very thin battery cable.
    FixBot'a Sor
    Yorum Ekle
  7. Tungsten T3 Battery Replacement: adım 7, 3 resimden 1. Tungsten T3 Battery Replacement: adım 7, 3 resimden 2. Tungsten T3 Battery Replacement: adım 7, 3 resimden 3.
    • Lay the two halves side by side.
    • The battery is usually held to the case by a small amount of adhesive. Carefully peel it up with a spudger.
    • Lay the back case aside.
    FixBot'a Sor
    Yorum Ekle
  8. Tungsten T3 Battery Replacement: adım 8, 3 resimden 1. Tungsten T3 Battery Replacement: adım 8, 3 resimden 2. Tungsten T3 Battery Replacement: adım 8, 3 resimden 3.
    • You should now be left with the front panel and the battery.
    • Gently disconnect the battery connector from the front panel. It's small and the pins are delicate, so be careful not to bend it.
    • When you install the new battery, you may find it useful to secure it to the back casing with some double-sided tape or even a small amount of glue.
    FixBot'a Sor
    Yorum Ekle
  9. Tungsten T3 Battery Replacement: adım 9, 2 resimden 1. Tungsten T3 Battery Replacement: adım 9, 2 resimden 2.
    • When reassembling your device, remember to place the small metal part on the front of the device and hold it while you insert the two small screws.
    • The screws won't stay in unless they're screwed into this metal part.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Whitney
318 İtibar
3 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-14, Diaz Fall 2011 University of Maine, Team 1-14, Diaz Fall 2011 üyesi
UMAINE-DIAZ-F11S1G14
2 Üyeler
1Rehber Yorum
The only thing I would add is before replacing the battery, be sure to backup your device since disconnecting the battery will do a total reset.
bill.costa_01 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 89
Her zaman: 8,693
