Ana içeriğe geç
Tungsten T3 Battery Replacement
Neye ihtiyacın var
  1. Tungsten T3 Battery Replacement, Battery: adım 1, 2 resimden 1. Tungsten T3 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two Phillips #00 screws on either side of the device, on the sliding panel.
  2. Tungsten T3 Battery Replacement: adım 2, 3 resimden 1. Tungsten T3 Battery Replacement: adım 2, 3 resimden 2. Tungsten T3 Battery Replacement: adım 2, 3 resimden 3.
    • Slide out the function panel.
    • Insert a paper clip into the two marked small holes on the back and push downwards while pulling the function panel gently.
    • The connector for the buttons will be revealed.
  3. Tungsten T3 Battery Replacement: adım 3, 3 resimden 1. Tungsten T3 Battery Replacement: adım 3, 3 resimden 2. Tungsten T3 Battery Replacement: adım 3, 3 resimden 3.
    • Gently remove the function panel from the device.
    • Be careful - it's still connected by the button cable. Peel the cable from the device carefully with a spudger - it is attached with a little bit of adhesive.
    • Carefully remove the connector and set the panel aside.
  4. Tungsten T3 Battery Replacement: adım 4, 2 resimden 1. Tungsten T3 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two Phillips #00 screws on the back of the device.
  5. Tungsten T3 Battery Replacement: adım 5, 3 resimden 1. Tungsten T3 Battery Replacement: adım 5, 3 resimden 2. Tungsten T3 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the two small Phillips #00 screws at the other end of the device.
    • A small metal part will fall out of the device from the other side. Keep hold of this - you won't be able to put these screws back in without it.
    Every thing looks great why don’t p you show cost +delivery
    Keenleyside - Yanıt
  6. Tungsten T3 Battery Replacement: adım 6, 3 resimden 1. Tungsten T3 Battery Replacement: adım 6, 3 resimden 2. Tungsten T3 Battery Replacement: adım 6, 3 resimden 3.
    • Using a spudger, gently separate the back casing from the rest of the device.
    • Be careful - the back casing contains the battery, which is connected by a very thin battery cable.
    There is an additional loose metal device which will or can come out. I believe it is to go at the bottom of the stylus hole. But there is no info in these directions. Ned to place it with the clip part at thebottom and make sure it stays there when reassembling. I put mine in upside down only to have to start over again to correct it. Author needs to edit or add a picture showing its correct placement.
    Curt
    curt_whitney - Yanıt
  7. Tungsten T3 Battery Replacement: adım 7, 3 resimden 1. Tungsten T3 Battery Replacement: adım 7, 3 resimden 2. Tungsten T3 Battery Replacement: adım 7, 3 resimden 3.
    • Lay the two halves side by side.
    • The battery is usually held to the case by a small amount of adhesive. Carefully peel it up with a spudger.
    • Lay the back case aside.
  8. Tungsten T3 Battery Replacement: adım 8, 3 resimden 1. Tungsten T3 Battery Replacement: adım 8, 3 resimden 2. Tungsten T3 Battery Replacement: adım 8, 3 resimden 3.
    • You should now be left with the front panel and the battery.
    • Gently disconnect the battery connector from the front panel. It's small and the pins are delicate, so be careful not to bend it.
    • When you install the new battery, you may find it useful to secure it to the back casing with some double-sided tape or even a small amount of glue.
  9. Tungsten T3 Battery Replacement: adım 9, 2 resimden 1. Tungsten T3 Battery Replacement: adım 9, 2 resimden 2.
    • When reassembling your device, remember to place the small metal part on the front of the device and hold it while you insert the two small screws.
    • The screws won't stay in unless they're screwed into this metal part.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Whitney
303 İtibar
3 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-14, Diaz Fall 2011 University of Maine, Team 1-14, Diaz Fall 2011 üyesi
UMAINE-DIAZ-F11S1G14
2 Üyeler
Bir Yorum
The only thing I would add is before replacing the battery, be sure to backup your device since disconnecting the battery will do a total reset.
bill.costa_01 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 7,101
