Ana içeriğe geç
Turnigy 9X Mode 1 to Mode 2 conversion
Neye ihtiyacın var
  1. Turnigy 9X Mode 1 to Mode 2 conversion, Turnigy 9X Mode 1 to Mode 2 conversion: adım 1, 1 resimden 1.
    • The Turnigy 9X, set up for Mode 1. Notice the left stick is centered in both axes, while the right stick is only centered horizontally.
    • In this guide "right stick" and "left stick" refer to the positions of the sticks when viewed from the front of the case.
  2. Turnigy 9X Mode 1 to Mode 2 conversion: adım 2, 1 resimden 1.
    • Remove the six screws around the back of the case.
  3. Turnigy 9X Mode 1 to Mode 2 conversion: adım 3, 2 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 3, 2 resimden 2.
    • Separate the front and back halves of the case.
    • Disconnect the cable linking the rear half to the front half.
  4. Turnigy 9X Mode 1 to Mode 2 conversion: adım 4, 3 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 4, 3 resimden 2. Turnigy 9X Mode 1 to Mode 2 conversion: adım 4, 3 resimden 3.
    • Remove the spring arm and spring for the left stick.
    • Push out the retaining pin.
    • Remove the retaining pin and spring arm.
    • Remove the spring.
  5. Turnigy 9X Mode 1 to Mode 2 conversion: adım 5, 1 resimden 1.
    • Remove the tensioner from the right stick.
  6. Turnigy 9X Mode 1 to Mode 2 conversion: adım 6, 2 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 6, 2 resimden 2.
    • Attach the tensioner to the left stick.
    • Make sure you have the larger slot and machine screw on the metal post.
    • Fully tighten down the screw in the plastic post.
    • Use the screw in the metal post to adjust the tension on the left stick.
  7. Turnigy 9X Mode 1 to Mode 2 conversion: adım 7, 2 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 7, 2 resimden 2.
    • Remove the retaining pin from the right stick.
    • Drop the retaining pin into the spring arm. It is a loose fit, so it will freely drop straight through if the arm isn't held level.
  8. Turnigy 9X Mode 1 to Mode 2 conversion: adım 8, 3 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 8, 3 resimden 2. Turnigy 9X Mode 1 to Mode 2 conversion: adım 8, 3 resimden 3.
    • Attach the spring to the plastic hook on the right stick.
    • Hook the spring over the end of the spring arm.
    • Line the spring arm up with the hole in the right stick casing and push the pin into place so it is flush with the side of the spring arm.
  9. Turnigy 9X Mode 1 to Mode 2 conversion: adım 9, 1 resimden 1.
    • You can now adjust the spring tension for the right stick.
    • Vertical movement spring tension set screw
    • Horizontal movement spring tension set screw
  10. Turnigy 9X Mode 1 to Mode 2 conversion: adım 10, 2 resimden 1. Turnigy 9X Mode 1 to Mode 2 conversion: adım 10, 2 resimden 2.
    • Reconnect the cable linking the front and back halves of the transmitter.
    • Close up the case and enjoy your Mode 2 transmitter.
Sonuç
To change from Mode 2 to Mode 1, use the same instructions but swap the left and right stick references.
21 farklı kişi bu kılavuzu tamamladı.
Nick
721 İtibar
1 Kılavuz yazıldı
5 Yorum
I just received my Turnigy 9X.
I ordered a Mode 2 Tx.
Sticks are ok (right stick stays in the center).
But when I open the tx, it says Mode 1 !!!
Left stick (up/down): elevator
Left stick (left/right): rudder
Right stick (up/down): throttle
Right stick (left/right): aileron
Is there something I can do ?
Martin Cloutier - Yanıt
Make sure you hold the spring arm down when you push out the retaining pin. The pin required some force to move and ended up moving all at once causing the spring and spring arm to fly across the room. I almost didn't find them.
Scott Stiegart - Yanıt
This is a great tutorial except...when you do this you still have your throttle on the right. You have changed the hardware and way the sticks feel but your throttle is still on the right. You need to make a programming change to switch to mode 2 left throttle. You must reverse which side the throttle is on. I found the solution here: http://youtu.be/sSWO_RrGDEk?t=2m25s
nmtreewalker - Yanıt
Really like this guide, i went from mode 2 to mode 1 but info is the same .... liked the extra comment for step 4 ... i didnt need to remove the pin !!
budmulla - Yanıt
MY OH MY! If I had a million dollars I would give it to you! I was heartbroken when i found out I had ordered the wrong transmitter, thanks to you, I now have the right one!
josiah Vaughan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 55,443
